ngoluba
Registered Member
Hi guys,
I listed this in the Engine section as well. I'm selling lots of other parts as well that don't fit a category so I'm listing it here also. Hope that's okay.
I'm over on the western slope (Basalt) and I'm parting out an '87 Suburban. I may be coming over to the Denver area in the next couple of weeks and could bring parts to your door for a small fee.
1987 3/4-ton Chevrolet Suburban 454 FI 2wd. 53k on the odometer, most likely 153k.
Drivetrain: TBI 454, Turbo-Hydramatic 400, 14-bolt full floater rear axle, 3.73 gears.
Exterior: Little to no rust, clear coat peeling on horizontal surfaces, minor dent on driver's side rear quarter.
Interior: Blue cloth. Front seats torn, 2nd and 3rd row seating like new. Has the rear a/c unit.
SOLD-454/7.4l Big Block - $450 Runs strong, 35psi of oil pressure at idle, but has piston slap on one piston under load. Has not gotten worse. I was going to install one new piston and rings but just don't have the time. Come drive it. $450 buys the long block.
SOLD-TBI Fuel Injection System - $250 Includes throttle body and injectors, intake manifold, computer, wiring harness with all sensors, fuel pump relay, computer controlled distributor. Starts immediately, runs strong and smooth as silk. Gets good mileage for a big block with clean emissions.
SOLD-TH-400 Transmission - $150 Transmission works fine in every gear. No problem I am aware of. Since this is from a 2wd Suburban, this transmission will work fine in a car as well.
14-Bolt, 10.5 inch ring gear, full-floating rear axle - $250 Very little rust. RPO code is GT4/3.73 gears. I have not pulled the inspection cover to verify the ratio.
42 Gallon Fuel Tank - $95 Includes mounting straps, filler neck, sending unit and new TBI in-tank fuel pump. No leaks, little to no rust. Great extended range tank.
Class III/IV Receiver Hitch - $65 With weight distributing hitch, rated for 9500 lb trailer, 1000 lbs on the tongue.
Front Clip $400 Includes right and left fenders, fender liners, grill, headlights, radiator support, hood. Chevy hood ornament intact. I can't find a dent, very little rust if any. Quality factory parts. Great front clip for a very long production run of Chevy/GMC trucks, Blazers, and Suburbans. Will work on many different year vehicles, not just 1987.
SOLD-Rear Utility Doors - $160 for the pair. No dents, no rust, hinges are tight, factory tinted windows. Handle missing but mechanisms inside work properly. Other doors are spoken for.
SOLD-Aluminum Wheels and Tires - $75 8 lug, 6.5 inch bolt pattern. Lots of tread left, no dry rot, no leaks, balanced. Includes factory spare with steel wheel and center caps (not pictured). Fronts are 235/85/R16 Load Range E, rears are 215/85/R16 Load Range D. These tires and wheels would also work great on a trailer.
Instrument Cluster, Gauges, and Bezel - $60 Lenses are good, bezel is good, no cracks, I believe every gauge and speedo works properly.
Lots of other parts available, this is a complete running Suburban. Let me know what you need. Get your parts quick, once I pull the motor, I'm going to pick at it for about a week, then it's off to the salvage yard.
I'll answer questions in this thread and you can call me at 970-379-0511 or email at [email protected] to talk about parts and prices.
