parting out k5 build SO CAL
MJB774X
SO CAL
dana 60 front 800
14bff 350
diy b52 bracket 100
fush bracket 45
nwf pas crossover arm and drivr side spring eliminator 175
2wd drop steering box arm 40
2wd box with front cap and top cap tapped for hyd asst 200
ruffstuff rear disc brackets 40
disc and calipers for rear 60
hyd asst ram 75
rear suspension brackets for 60" suburban springs 200
400/205 with hd torque converter, rails for twin stick (no shifter) 450
brand new ext brake lines 65
shipping on your dime
will the extended brake lines work on 14bff with disc brakes with 8in lift
"Nwf pas crossover arm and driver side spring eliminator"
Is this a crossover steering kit?
Im interested in the brake lines and the fush and b52s. What part of SoCal you in?
Is the 14 bolt free floating? What year did it come from? Same goes for the Dana? I have a 72 blazer and don't massively want to relocate the spring perches. Do they have disk brakes etc?
