Parting out the flatbed. Its on, lots of stuff.
Stomis
Professional Amateur
Roseland VA/PtPleasant NJ
List updated 11/1/11
If youve read my build thread youve seen my truck. Nearly everything is for sale.
1987 Chevy V10
LO5 350 bored over to 355, RV camshaft 40,000 miles. Doesnt burn oil, no noises, ticks, knocks. Sold as long block- SOLD
TBI injection. Includes throttle body freshly rebuilt about 5k ago. Intake manifold, sensors, harness, computer, dizzy - SOLD
SM465 rebuilt 1000 miles ago. Updated 3rd gear replacement. 32 spline output. Trans needs a new front seal, was either defective or lost its spring on the install. - $500
32 spline NP208 rebuilt 1000 miles ago. -$250
DiY4x clocking ring - $50
Custom 14b 10.5 inch rear axle converted to 6 lug semi floater. Uses stock 10b drum brakes, stock full floater gears/lockers, custom semi floater shafts with 9in style outers. Locked with lockrite. Mildly shaved - $500
36x12.5r15 TSL Radials on 15x10 4in bs 6 lug black wagons. 2 are 90% 2 are 80% spare is like 50% and I have a second spare not on a wheel Ill throw in thats like 25% - $600 (The rims have no value to me)
Then theres all the smaller stuff which I guess Ill just leave open to offers.
Non tilt manual steering column.
Good remanned intermittent wiper motor - SOLD
Wiper delay module (bought new at dealer for $70) - $25 + ride
Gauge cluster - $25 + ride
Glove box - $20 + ride
Center console - $20 + ride
Chrome mirrors - $30 + ride
DIY4x Shackle flip - $150 w/ shipping
52in springs in the front (used original springs, thinned packs) - $50 + ride (available this weekend, need to be pulled for shipping quote)
56in springs in the back (used original springs, thinned packs) - $50 + ride (available this weekend, need to be pulled for shipping quote)
Zero rates
SBC starter - $20 + ride
Single serp belt/v belt accessories
Home made front winch bumper
Flatbed - $200 w/o tool boxes, pickup only
New blazer gas tank
Anything else youve seen on my truck Im forgetting.
Things not for sale or also already sold: CB, Hydro clutch setup, front axle and crossover, steering box.
interested in;
-2nd for shackle flip.
-will the clocking ring fit a 241?
-are the 56's lift or stock height?
-zero rates.
interested in;
-zero rates.
Truck has a dana 44 in it thats not for sale. Using it or my trooper.
Clocking ring is the same for a 241.
All springs are stock height no lift springs.
the 52's...stock height?
can the tbi be used on a motor with a diff cam? or does it need a cam for that. I dont know what mine has:dunno:
TBI can be used on any motor. Generally any cam thats not too far from stock works fine. My motor has an "RV" spec computer camshaft in it which is designed for a little more torque and to be computer friendly. Guys on here can guide you better than I on whats too much cam for the stock tune.
How much for the zero rates? Is there enough for both axles?
I believe I do have two sets. DIY4x sells them for $33 a pair. Im asking $25, Ill pay for the ride on them, no hardware with them though.
Yes 52s and 56s are both stock packs that I thinned out a little bit. Ill get leaf/overload counts on them tomorrow.
chevysmithz71,
He already answered your question;
Quote:
Originally Posted by chevysmithz71
First in line on the shackle flip, and crossover for the 60. How much please?
$150 + the ride for the shackle flip. I need to double check what size shackles are on it.
chevysmithz71,
Oops didn't see that. O well, too much for me. I'm out.
Does the TBI include the O2 sensor?
I assume if it does, then it should be a "plug and play" kit for a SBC, I just need to widen the holes in the intake manifold, or use an adapter plate with my stock manifold.
Thanks!
TBI injection. Includes throttle body freshly rebuilt about 5k ago. Intake manifold, sensors, harness, computer, dizzy - $250
will this work on my motor?
im in NJ too....
i have a 1991 L05 block out of a caprice police car but put 1996 tahoe vortec heads on it and a comp cams extreme 4x4 cam...
so everything here to put on and go? let me know
your 30 miles from my work and 70 from my home.. so i can drive to get it..
so im guessing ill need a new intake? i have a carb intake now...
a weiand power plus+ vortec intake
