parting out the suburban
dukekid513
Registered Member
Kenilworth, New Jersey
EVERYTHING IS SOLD
i have decided to part out my beautiful suburban. i have a front dana 60 with 4.56's and a rear 14 bolt 4.56 w/ disc brake conversion. rear has a locker. not sure what kind tho.
dana 60- $700
14 bolt- $400
both for $1000
located in central new jersey. i can deliver within an hour away. pickup prefered. NO SHIPPING
Would be all over this ASAP if you were on teh right coast!
are there any other parts for sale? steering setup possibly? springs?
Everything is for sale. I have 12" springs, shackles, and all the crossover steering components (2wd steering box ,tie rod, pitman arm, also the raised steering arm if you take the front axle)
does the rear springs have pinion shims to correct the pinion angle from the 12" lift or has the rear axle been turned up with rewelded spring perches to correct the pinion angle?
