nomad350z
Registered Member
I've recently come into ownership of an '83 K5 Blazer, and am trying to figure out what path I wish to take wtih the truck.
Currently it has a lo-po 305, TH350 combo and the original transfer case. If I'm to keep it a gasoline motor, can I use a 700R4 withe the NP208 transfer case? I realize the 700R4 is electronically controlled, but there is a kit on summit to override that....
Also, I have a GMC pickup (late 80's, maybe early 90s) with a 6.2 turbodiesel and a standard transmission (I believe its a 4 speed with an ultra-low stump pulling 1st gear). I've dabbled with the thought of swapping this in for the blazer's 305, but was wondering if it would bolt up to the NP208.
Its going to be a daily-driver/weekend warrior build, so nothing too crazy (or expensive). Will either of these setups work?
Thanks guys.
The Newb, fresh in from thirdgen.org
Thanks guys.
