wayne
3/4 ton status
I am planning to go full hydro during the next K5 rebuild. With that said I have no idea on what my current stuff is worth. I will be selling everything except my steering pump. Here is the list of parts:
1. 2 wheel drive steering box, rebuilt and tapped by WTO. About 5000 miles on it.
2. Drop pitman arm. About 5000 miles on it.
3. Rockstomper sleeved bent draglink with ends. 3" to 6" lift. About 5000 miles on it.
4. Sky D60 steering arm. About 3000 miles on it.
5. Rockstomper sleeved tie rod with ends. About 6000 miles on it.
7. PSC 1.75x8" ram and lines. I don't think it has 1000 miles on it.
8. Ram mounts on both the axle and tie rod plus hardware. The tie rod has a clamp on it so you can set the toe without cutting tabs off and rewelding them on.
9. I might have a brand new stock replacement pump to go with it. I have to check my parts bin.
10. Forgot to add, I will include the ORD bolt on steering brace and bolts.
I know I have a chunk of change in this stuff and it works very good. I would like to sell it as a complete set up so all that is needed is somebody to modify their stock pump or buy a good aftermarket pump. Any idea on what a good price would be for everything?
