TX Parts Vehicles
Jimmy85
Austin Tx
2 parts trucks, no titles to either. Interiors are shot on both. I can have a bobcat available to help load.
1/2 ton 2wd c10 long bed. No motor or trans, most panels are dented. Don't see this one coming back to life. Good rocker panels, 12 rear end, hydra vac brakes, tilt wheel. $200
1/2 ton 4 wheel drive Suburban. No rear end. Only good for front 10 bolt, 700r4 trans, 241 transfer case and tilt column. $50
Would you be interested in cutting about an 8”-10” square of cargo floor from the Sub? I just need a nice, flat piece for a patch.
Possibly. If I have to have the carcass just hauled off in the next week or two, I'll cut you some. Passenger or driver side? Assuming the front pans.
Ok I understand, just let me know.
The piece I need is from the rear cargo floor. I need to patch a small hole in my K5 back by the fuel filler cover.
2nd in line for a 6" x 6" cargo floor metal chunk . want to make a nice form fit plug for my gooseneck hitch hole .
Is that nicely weathered tongue and groove barnwood in the burban?
How much on the rear air deflector on the suburban? I'll take the deflector, mounting brackets and hardware on the back of the suburban?
Shipped to 36977 pls
