You cannot just swap in a 73-74 grill with your current core support. You need all of the brackets at a minimum and a 73-74 core support ideally. The 73-74 core support has the outer brackets as part of the main structure of the core support.
I have the mirrors you want coming off of my C10 to be replaced by sport mirrors and a good section of the dash for the radio patch panel in my '75 GMC parts truck. I can get you pictures later today.
I'd recommend a new clear gauge cluster cover, all the old ones turned yellow with UV exposure over time.
Here is a picture of the dash.
If you found a good set mirrors locally I'd say go for them. Shipping glass can be a pain.
I have the spare tire mount that goes in the rear cargo area,....is that the one your needing?Bump. Updated with parts I need.
Hey, I have your center console. It'll have to be painted.
I'll grab one tonight. It's era correct, just baby poop green.Do you have a pic?
I have a 208 and the crossmember, I also have the adapter to either 465 or th400.Looking for some parts for my 1978 K5. Located in Lincoln Nebraska.
*Updated
73-74 orange turn Signals
Center console
Door patch panels to cover speaker holes
Door sill plates
Plaid seat covers
Spare tire mount
208 crossmember
208 transfer case 32 spline
Hydro pedals
View attachment 329385 View attachment 329386
Unless you are missing your crossmember, your original should be compatible with a NP208 adapter. That is, if you use the 81-84 tall adapter.
I have a set of hydro pedals and console/tire carrier if the others fall thru.
