hahaha
You ot to start a build thread in the "Driveway" forum. Then you can ask all your questions in one place. It can help keep your answers and progress organized.
Check to make sure it's door sag first, it might just be miss-aligned. With the door almost closed pick up on the bottom corner (latch side) and see if it's loose. The door will be at it's loosest in this position and you'll find wobble easy. If it's loose then you'll need to replace the pins. (there are "how to" write ups all over, use the search button) If it's not loose, you'll just need to adjust the hinges with the bolts.
