Ned Kelly
So my D60's original front spindles have about 160,000 miles on them. They are showing signs of grooving where the oil seals have worn into them. Should I not worry about this - I do alot mud/water. Is there a 'speedi - sleeve' for this application?
http://www.pirate4x4.com/tech/billavista/SpeediSleeve/index.html
..... or should I just try and install the oil seal alittle less flush into the back of the hub?.....or what about installing the oil seal backwards, and the sealing lip would be 1/8" away from the old groove - would that be ok?
