Dont run without one...
A PCV system robs no power,reduces blow-by,improves ring seal,avoids excess pressure in the crankcase,so seals wont leak,etc..I'd not eleminate it,its very important on a "daily driver"..it reduces sludge and condensation in the crankcase,a very important feature that aids engine longevity..
I see hundreds of "botched" PCV systems in older vehicles..either they are eliminated entirely,or the owner buys cheesy chrome valve covers with no provision for the breather ,but has a spot for a PCV valve!...the result is the valve often sucks oil right into the combustion chamber (few valve covers aftermaket have baffles under the PCV opening too,that is important!)..
Many guys remove the breather pipe that goes into the air cleaner on high milage motors with lots of blow by,to prevent the air filter from getting "oiled",or a puddle of oil accumulating in the air cleaners base..it will increase air filter life,but without the additional "draft" from the intake vaccuum,blowby instead just escapes under the hood,making a nauseating smell and oiling everything in sight!..GM could have solved this by putting the "bowtie" filter INSIDE of where the air filter sits instead of outside of it..
In days of old (pre 1963) ,engines had no PCV valve,but instead used a "road draft tube" to ventilate the crankcase..I assume marine motors use them instead of a PCV valve--they have to have SOME kind of crankcase ventilation,or they would be peuking oil everwhere!..
