PCV valve on 400cid engine
Chris1972
On my Carter 750 carb there is somthing called pcv vale.
What is it and do i need to connect it to my Edelbrock intake somewhere. And if so where
ore can i just block it.
Engine is a 400cid from before 1975
Chris
www.broadpark.no/~csteinsv/
i think what you are talking about is the Positive Crankcase Ventilation valve.. it goes to your valve cover and sucks out the pressure from your crankcase when the engine is running. it doesnt use any hoesrpower and keeps your crankcase from getting contaminated. it will also keep the gases from blowing out your seals/gaskets. i wouldnt block it. just hook it up to a new pcv valve (under 5 bucks in USA, probably 20 where you are), or clean your old one with WD-40 and make sure the little ball rattles. hope this helps
AIRBORNE!!
oic--- i think that you could probably get an oil fil cap that has it thru the center. i am pretty sure i had one of these on my old impala. its been a while though. i watched your video. sounds good... i love the smell of a fresh rebuild--burning all the assembly oil, the fresh paint getting hot, the frustration of getting all the little adjustments squared away--- ahhhhhhhh !!!
AIRBORNE!!
I can't believe no one else responded to this. You need to run the PCV system, or at least breathers. PCV IMO is probably more beneficial than just breathers. In any case, if you don't run PCV, you will blow out gaskets. PCV removes the blowby, fumes, etc from the crankcase. You will end up blowing gaskets, at least. Most aftermarket valve covers I have seen are pre stamped on the underside so that you can break the holes out for breathers or PCV valve.
Dorian
My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
