pedal bushings easy to replace in truck?
Got Smoke?
Bethpage, TN
Ok I had planned to pull the pedal assembly out and replace the sleeve and bushings on my clutch pedal while I have the trans out this week replacing the clutch. My clutch has a overly annoying squeek when pressing in.:doah:
Upon closer look I realized the steering column has to come out in order to pull the pedal assembly out, nah..not happening.:rolleyes:
Just curious...but with the gauge cluster out it looks like I can loosen and remove the bolt holding the pedals in place and they will just fall out.
Has anybody done this job in the truck before? Is it fesible or is it a major PITA?
