84CUCV
3/4 ton status
it a 91 chevy 3/4 ton 4x4 suburban. have a new MC, front calipers and all i did in the back was cut the drums. motor off i hear a hissing from the booster when i hit the peddle. could this mean the booster is shot? thanks
bleed them 3 times. everything is tight. no leaks. the mater is rebuilt, so maybe they did it wrong. no leaks at the booster that i could find. still right to the floor
think i might get another MC. anyway to test the booster thanks
Check softlines, wheel cylinders, calipers, the master, and consider vacuum or pressure bleed if you've not already.
)give an update when you get that done.to think of it. no i didnt. i got it put it one. and filled it up.
