peein' fluid at full lock?
stumpbuster
farmington, Ct
finished my 1 ton swap, (which consisted of different steering components) and now only when i crank it all the way "right", im leavin trails of fluid..:confused:
cant really tell where its comin from, i aint leakin other than that though, so i must be straining something in the steering box? seal??
fluid smells too, does power steering fluid stink? clueless:crazy:
Are you yanking the wheel against the lock? If you dont have bump stocks set up correctly to stock the knuckle and the box is limiting your steering thats very bad.
whats bump stocks?
true though i should have another head ta see if im hittin stuff...
although when i had my 3/4 tons, i had the same lift and no issues.
i wouldnt see why just doing an axle swap would change anything, but it did:( some how some way
so
