Probably a bit different due to the manual, but I've got a small cam in mine (.454 max lift IIRC) and nowhere near what I'd consider ideal gearing for acceleration (works out to 12:1 final in "first") but I'm really impressed with mine on takeoff and crawling in low. FWIW it feels like it starts to choke right around 4K, but that's 65MPH in "second", and gets up to that speed plenty quick which IMO is acceptable. I should get out and time it 0-60MPH, at least that would be quantifiable.
I'm sure a large amount of the grunt comes from the long runners of the TPI (stock TPI numbers were pretty impressive compared to the truck engines up until 1996), but I also believe the Vortecs and long tube headers are a significant improvement over previous stock configurations, assuming a mild 350.
Most information indicates Vortec heads by themselves are worth ~25HP over a stock head on a stock motor. Obviously HP isn't the end all for a truck motor, and low end torque is fairly hard to quantify (most dyno numbers start at 2K), but the Vortecs should easily produce a significant amount of torque compared to older heads, especially on a mild ~350CID engine. The TBI heads are apparently pretty comparable to Vortecs when it comes to low end, so you'd expect that in a truck, TBI would seem fairly strong vs. older design heads. If you compare the 5.7L TBI truck engine numbers to the 1996+ Vortec 5.7L numbers, the difference works out to about 25HP, meaning if the cited +25HP number for the Vortecs is right, the induction system isn't the difference.
Very big changes in how it all runs with tune though...timing or fuel off a bit, and it's immediately noticeable. At least you are able to monitor what your setup is doing AFR-wise.
please post specs pics and videos of this bad boy!
