the air cleaner housing.
that makes sense, to port it into the airflow; to have it shooting straight up into the primary venturies of a carb does not. On the note of super heated air catching air filters on fire; I am fairly certain atomized fuel has a much lower flash point then paper.
Uh, you are absolutely wrong. My post was stupid as hell (I was in a hurry and didn't get to think on it) but EGR does not simply pass under the intake. FWIW I believe the truck EGR systems rely on vacuum to pull it into the intake, therefore into the air cleaner wouldn't work. The simple fact of routing it through the intake was likely a cost saving measure, as well as having nothing but the valve itself to fail. No hoses to leak, etc.
I'm not going to even spend the time dredging up a plethora of information on how EGR works, and has ALWAYS worked (as it's everywhere on the 'net), suffice it to say, EGR has to make it into the incoming air/fuel mix before it reaches the cylinders. It has nothing to do with heating the engine up. That crossover on smallblocks was there before EGR was even used, which WAS solely for heating the intake up.
Well for what its worth both of our posts were off. But its clear by the pics those holes go straight into the exhaust crossover passage. That edelbrock intake is not a EGR version though. Hes got it all figured out now though so all is well.![]()
