ciffer
I put a TBI Performer manifold on my 88 sub last night. I am running into two small issues.
The first one is that there is a vacuum bung on the rear runners between the injector and the distributor. The original plug fits into the bung but can't clear the fuel lines because the bung is right under the fuel hardlines.
Is there a different plug I can get that is low profile, or should I just find a plug and run the vacuum line somewhere else?
The second problem is that the power brake booster hard line doesn't reach to the bung, it is about two inches two short.
Should I bend a new pipe for this, or just figure out how to move the pipe and run new soft line to the hard line?
