Phx, AZ: 76 k20 rear leafs, driveshafts, sway bar, gas tank, etc
nutt7
Ahwatukee, AZ -> JBLM, WA
All sold/ gone!
Cut and pasted from my CL ad...locals only please:
Edit: ***Going to get scrapped on Wednesday, so let me know***
I have a few parts left over from a project. Let me know if you are interested before they go to the metal scrappers! All parts are from a 3/4 ton 4x4 long bed chevy truck. I bought a rolling frame to salvage the axles.
Front driveshaft from np205 to d44 $40
Rear driveshaft from np205 to 14 bolt $40
Rear leaf springs $40
Gas tank. I think it was mounted on the passenger side. It's either 29 or 31 gallon...I forgot. You guessed it. $40
Engine crossmember with *both* mounts. $20
**edit: I also have the sway bar with spring perches for the dana 44/10 bolt for $20**
These are the ONLY parts I have. All parts have superficial surface rust here and there...nothing to worry about. My prices are negotiable. Let me know if you need pictures or measurements, verify specs, etc.
How any leaves are in the springs? Is the arch still good or are they worn out?
Seven leafs. Here are some pics of the arch. One has a higher arch, but the pin is not tightened. I also read that one spring is usually tougher due to the side where the gas tank is...not sure if there is truth to that. I also never saw these springs loaded...only on a rolling frame, which sat level. Let me know either way, I am going to scrap it all tomorrow morning.
I believe so. They measure 52" end to end. Can you measure yours? Until then I will see if I can find out for sure.
I think yours are 56", so I don't think mine will fit. Go measure eye to eye along the top leaf to be sure and let me know.
One guy bough the front driveshaft for $40, all 780 lbs remaining got scrapped for $64. Except the gas tank! It's still available. My burb weighs 6120 lbs[emoji15]!
