pic request - 78 k5 fuel line routing
wazzabie
Washington State
I'm trying to figure out how I should rought the fuel line in my 78 k5 blazer/ Anyone willing to share some pics?
Which part?
From the fuel tank to the mechanical pump (or is it electric?) or from the pump to carb?
Any reason you can't run it like stock? Would seem easiest, since the attachment points for the clamps are already there.
That is how I would like to run it however I can't figure out how the stock line went. There are also brake lines that run by it. I'm not sure if the brake lines go under or over. Some of the connection points where also shared with the brake lines. It is a big mess.
