icemaneric1
Registered Member
Picked up my first K5 on Monday, 91 fully loaded. No body lift, don't know if it has a suspension lift, but it has 33" on stock alloy wheels. Tires rub. It's a rust free California Truck with 149k miles. It needs work but for 500 bucks who can complain.
The previous owner said it may have a spun rod bearing, but there is no bottom end noise, no metal shaving in the oil, and it has good oil pressure, I did notice a misfire, so I did a compression check and found two cylinders dead. Cylinder 3 & 6. 40psi on both. Oil looks good not milky, no white smoke out the tail pipe, so my guess is a blown head gasket.
Any how I have a few questions. I did a search and found that the vortec heads bolt up to my block. What things do I need from the vortec donor besides the heads? My second question, is there a intake manifold that will bolt up to those vortec heads that will allow me to run my stock TBI?
