pickup trailer #3 in this build .
well i just like building these things from left over parts .
14ff cut up for the tubes and hubs . remove the brakes and cut the axle shaft off the flange . clean and inspect the bearings and pack in grease . install new seal in hub . use a freeze plug in each spindle hole to keep the grease in the hubs . then a chunk of 4" sch-40 o.d. pipe for the tie together .
then 6.5 feet of 6" C-channel or ox tube gets you a 33 3/4" cross section to tie the frame together . then 2 22" chunks for the 2 sides of the tongue section . then a universal hitch bolt on plate to tie them together . i prefer to just use a 2 5/16" coupler for my builds . i then use a 2k-2.5k jack with the weld on plate option .
were doing 265/75/16 load range E tires . were using stock 4-leaf 52" springs from a project left over job . this is a 2wd c-10 long bed frame .
more to come as i hope to finish this tomorrow . and got to love a high lift jack for clamp work .
