PICS!!i got another truck and went against my own rules
original balzer
roosevelt utah
about a week ago my neighbor gave me a 67 chevy c30 cab/chassis model.
i remembered this guy that had several 67-72 trucks so i went to see him after work today to see if he had anything i wanted. well he didnt have any 67-72 stuff worth dragging home but he did have a 86 2wd 1/2t long bed that looked pretty dang clean so i asked him what the deal was on it. he looked at me for a second then said dont you have a older jaguar with a 350 in it? how did he know that i wondered? then he said his bioy used to work at my work and remembered me. i told him yes i do and he said ill trade ya that truck for the jag. (a little history on the jag. I have had it almost 8 years now and never do much with it. I did spend about $5500 on it when i put it together but lost intrest. so it hadnt got drove much more than maybe 2000 miles in those 8 years) i said well id have to think about it does the truck run? he said yes and pulled some papers out of the glove box. recepits for machine work and parts, said the engine has about 1500 to 1800 miles after the rebuild. so we jump started it and i drove it down the road solid truck ran fine i made the trade. well i got it home tonight and looked it over the body is almost perfect. no rust no major dings. so i broke out a magnet to check for bondo in all the usual places, and guess what i didnt find any. curious i went back to the glove box and pulled out all the papers. there was registration for the guy i just bought it from and one for AZ state water improvment. SCORE! rust free AZ truck. then i found the recepits and looked them over.
350 4b main clearanced and bored 30 over. clearanced? sure enough i look though the rest and it has all the goodies for a 383 stroker. test drive time. i drove it easy till it had time to warm up (sitting since april 2nd) then got on it
and it didnt pull my hat off my head. bummer no 383. so when my dad got home i was showing him the truck. i had the air cleaner off to check things over noticed it had the q-jet with the elec shut off valve. (right front top of carb) you know the ones that arnt worth rebuilding? i fire it up for dad and hes running the throttle with his hand and asks "the secondaries open up fine?" and when he throttled it wide open the butterflys didnt move. got to looking and the linkages are all missing and theres a plate of some sort under the back half of the carb. so tomorrow i gotta try a diff carb and get some pics if i can find my camera. more later
balzer
The secondaries shouldn't open if the truck is just sitting there in neutral. There has to be a load on the motor for the secondaries to open.
Now then, I looked it over realy well, its a great score. The carb situation is, someones made a q-jet into a 2bbl, why i dont know. Also the dist. does not have a vac. advance,(built that way) there was some vac. ports not pluged on both the carb and the intake. I pluged the holes and drove it again and im thinkin even with the carb issue its got to be at least a high performance 350 if not the 383 the reciepts indicate. It runs damn strong! I browsed though my shed and dont have a good q-jet ill have to rebuild one and try it later. I dont know what i want to do now though. I have some choices i have a 83 3/4t with a bad 6.2 and a shot body, and i have my 85 k5 thats in peices. i have the d60/14b/sm465/np205 and a 3" rancho soft ride under my K5. Im seriously consitering building 1 nice 1 ton 4x4 out of the 3 trucks.
*the body and engine from the 86 2wd, the frame on the 83, and drivetrain from the K5* but im not sure what to do. It would eliminate a ton of junkers sitting around and give me a realy nice truck when it was done. Im open for oppinions sugestions.
Balzer
That's a nice looking truck. :waytogo: Look like it has an '81-'82 front bumper...are the parking lights hooked up in there? I can't tell from the pic, they look empty from here.
they are empty the signals are in the grill. I realy dont like the bumper but it is NEW recepit also in the glove box. And the diagnal supports are missing
