pics of linkage on double pumper?
raymos
Who?
NOR CAL
:confused:
i would like to see the throttle linkage/kickdown (mines TH350) linkage setup on a holley double pumper. tryin to get her runnin as good as possible for the fall/winter seasons and this is high on the list. thanks
Do you have the aftermarket bracket or stock that hold the cable should be a square hole the cable locks into.
IF so then just pin it or bolt it to the linkage usually on top there is a multitude of holes just find the one that pulls the cable the straightest.
i used the bracket that was on the truck with my q-jet, but i had to modify it to make it fit. now the go pedal only has ~2 inches between no throttle and full ( im not sure if im even getting full throttle with the setup now.) it used to have a lot more travel than that.
