FRIZZLEFRY
I don't think he's too concerned about the thickness of that box tubing, I think the concern is more HOW you attached the joint to the tubing - meaning, weld some tabs to the tube and bolt the joint through those tabs.
If you bolt the joint through tabs welded to the tube you will no longer have the orbital aspect of the joint
All of the force that will be exerted on that joint will be straight up and straight down.And just about all of that energy will be spent trying to push that joint up through that tube
