mountainexplorer
Step one: Disconnect everything
Step two: Stick engine hoist through side door or window and lift motor up
Step 2.5 needed in cases where main door is not up front- use cart and roll motor to doorway.
Step three: Pull motor out main door using tow vehicle- it is more fitting to use another motorhome to do this, just to keep things more consistent.
Example 1: 1974 Open Road 454
Example 2: 1972 Open Road 402 [Note step 2.5 required]
Thanks for the tips.
I remember he did that with a mopar 440 and an RV back when I was little.
