what do you guys think about this Idea: the bottom arms are adjustable. they have an excentric bushing much like a newer Jeep does. I figure the dealer is required to set the axle to spec only and i figure this adjustment is to set the castor/pinnion angle to factory spec all at once . Do you figure i could add + or - castor to both sides at the same time by moving this adjuster (equal amounts on each side) and by so mabe find a compromise between the two wheels? i figure the odds are that one C is welded right and the other (pass side) is rotated, so at stock spec one is dead on and one is way off, perhaps i can "split the difference". one a little to the + of specs, and one a little - of the specs. Anyone think this is a bad Idea?
