pictures of lmc floor pans?
syclonekid43
ct
i just searched the whole body shop section and found nothing helpfull.
im doin a body swap project i got for free off my buddy. he has all the floor pans. buddy of mine who is a welder said he was gonna help me. left me high and dry with a truck half cut up on the driver floor. i cant seem to figure out how the front part of the floor pan goes in. not sure if it goes under the rear section or above it. not sure how it butts up to the rocker. i cant seem to get a pinch for the door gasket to go ot. i figured out the rear section and inner rocker, but lost of the front part.
so does anybody have pictures of the front floor being replaced?
I don't know if it will help, but my build thread (link in signature) is where I started my build by replacement of the passenger side floor.
i saw that one before. nice work. what i really need is to see how the floor pan goes where the rocker is. i cant seem to figure out how to leave the pinch for the gasket to go on.
you have any pics from the pass side floor after the panel was in?
my body is bad real bad. rockers and all rotted right off.
im getting to the point of either parting it out or looking for a cleaner body and swap another one on there
I had that same problem in my truck, ended up bending the new panel up 90* to hold the gasket then welded it to the existing panel. Sorry I don't have any pictures of it and the door is welded shut now. If I ever put in another floor I wouldn't use lmc's panels they were more trouble then they were worth
thanks for the info. i thinki had it with the lmc pans. im goin to look at another blazer today. i was told the floors are solid and it needs rockers
Will these help ya ?????
Truck cab I did floor pan,inner rocker panel , outer rocker panel, kick panel ,& floor brace/cab mount.
The weather strip lip was part of the outer rocker panel ,on the ones I used,don't know about others as this was my first attempt at body work, turned out ok, I see alot of room for improvement though.
All the panels were from Chevy Duty ,they have changed thier name to Classic Parts http://www.classicparts.com/
nice work. thanks alot those will help me out.
i went out and bought another k5 that the floor was better than mine.
the new body still needs rockers and just a sdmall part of the driver floor.
