Found Piece of Floor / Trans Tunnel
nvrenuf
Holy crap, it's running!
Mobile, Al.
I’m in need of a roughly 12”-15 square of floor on the pass side of the trans tunnel immediately behind the “removable” hump for my ‘91 Blazer (not sure what all years fit).
@kennyw ?
I probably have what you need. A picture with the area highlighted would help.
Here's a pic, I just need the area inside the red square.
I need the vertical wall of the hump with the top corner where it rolls over flat about 2"-3" (just before the center console boss is ok if you need to save that) in and down to where it meets the floor pan, I don't need any of the floor pan itself. The piece needs to be from the edge of the rear lip of what would be the removeable hump (mine is bonded) back about 12" of so.
The section I have is from a pickup cab and very different in that area. Probably not close enough to be useful.
Yeah, that looks like mine. What would you want for a piece?
(Zip = 36695, residential)
@rockin kw here’s a pic of what I’m fighting. I cut it for a cool kid shifter then realized the cable linkage tabs were hitting the hump and floor, see the dimple and rusty spots. I’ve since cut the vertical area out and tried to build over it to clear everything but I hate it so I want a patch to work with when I start over. I will need about 2 inches of floor pan but not all the way to the seat bolt hole.
Yeah, everything else looks great. For the sake of shipping, it only needs to be 9” long front to rear (you may have longer mapped out).
Whenever you are ready, shoot me a price shipped to 36695. No rush.
