It is. I've been distracted working in the blazer 1 ton swap for the last little bit, but it's still alive. I have an event the end of March, but this summer I'm hoping to start work on a ttb swap for it to get a bunch more travel in the front end.
I don't have time for anything else, so I sure hope you are right. I'm putting it back together tonight.I am guessing that a warped head would not do that in those directions. Bad head gasket, too much boost plus some heat would do that. I would put a straight edge on them and look at them and then call it good.
There are marks on the front of the engine that you are supposed to line up as well, but the marks on the belt really make it a lot easier to know you are on the right spot. There wasn't any sign of the valves contacting the pistons, luckily, so it could have been a whole lot worse.I'm not familar w/ having the belt marks be the master of the timing like that. Interesting concept
Unfortunately no. I have 2 TTB axles sitting in my shop, but with it not running right, I haven't messed with the suspension.I have been wondering on what was going on with it. Still no ttb?
I can see how that makes sense. I'm going to do a bit more reading to try and be sure, but I think you are right.IAT is usually always for the air coming into the engine but on the diesels I'm used to working some have it right after the air filter and some have it in the intake manifold. Usually if it's in the manifold then it's MAT(manifold air temp) obviously. MAP you would definitely want to be reading boost.
That reminds me of a meme I saw recently. Basically it said, whenever giving your buddy advice on how to fix his vehicle, be sure to say "but I dunno though" at the end, just in case everything goes horribly wrong.But I'm just a guy on the Internet![]()
