Pilot bushing..???
NoSmog73
lodi,ca
I got the 465 ready to go in but the bronze bushing ??? Does that get driving in the end of the crank for the shaft on the 465 I started to drive it in there but it is WAY tight and wanted to double check first before I went any farther...Thank you /forums/images/graemlins/grind.gif
yep. thats where i put mine... but if i remember correctly it wasnt that tight, make sure you dont have it in there on an angle...
I wouldn't use the BEARING. Mud/dirt/water doesnt get aalong with it. Atleast the bushing will wear a little and not toally sh!t out.
[ QUOTE ]
[/ QUOTE ]
That stuff shouldnt get in there, put a cover on the bottom.
covers are NOT water/mud tight. If you actually wheel it in the deep stuff it WILL find a way in.
I think a pilot bearing is a very bad idea and I have never ran one, nor do I ever intend to.
Bushing is the only way to go IMO. If that bearing fails your input shaft bearing will fail shortly as well. No moving parts in the bushing to fail. Put a finger full of grease in it and you're done.
I agree with you guys on the pilot needle bearing vs. the bronze pilot bushing. Needle bearings are better for racing applications only.
The bronze bushing you are installing is supposed to have a very, very tight fit, so do not freak. You are putting it in correctly.
Having a bushing installer tool is good, but not absolutely necessary. When you are installing the bushing, without a bushing installer tool, make sure you do not distort or smash the inner hole on the bushing.
One thing you need to remember, the most critical part of a clutch job is the proper alignment of the clutches to the pilot bushing. It can make the difference between cussing and spitting, or having a big smile on your face for a job well done. Make sure you use a line up tool. I like a splined line up tool better than the universal cone types.
I use a spline alignment tool as well. An old input shaft will also work.
Having a 4 speed is great nearly all the time. Don't skimp on a clutch as replacing them is the biggest pain in the ass to owning a manual. Now that I have a hydro clutch, a high quality flywheel and disc, I wouldn't trade my 4 speed for anything.
I agree! An old input shaft is the best line-up tool to use over any other.
Now that i broke one off i have to make a handle for it and im set /forums/images/graemlins/grin.gif
Also from what i have learned here in school about bushings such as these they arent suposed to be greased. They should be self lubricating. Although i have heard it done both ways with no problems. /forums/images/graemlins/dunno.gif
