pin-out?
Speedo
Talkeetna, Alaska
I have a pin-out sheet that is supposed to be for a Camaro and I was told that it was the same thing for my engine/harness. I have a '99 5.3 that came with the factory harness. I started on the harness today and there are several differences. Does someone have a pin-out sheet for the connectors for my harness? Or can somebody point me in the right direction?
Gus
let me find mine again. i just did the swap, but with an 02 5.3. the ls1 pinouts are somewhat different than the truck.
heres one from ls1tech.com http://www.ls2.com/boggs/torques/99pinpcm.htm
hit me up on aim if you need to ask any questions...i can tell you the easy way to get it running...
and LS1tech.com is your friend...
My sheet is the same as the one you linked. If you have Word I made a list of the differences between the sheet I have and the harness that I have.
Gus
Gus
hmm...send me what you have. ill have to go back and see what other pinouts i used. there were 3 or 4 that i used, but were for 02 pcms...which 01+ pcms are better than the 00 and 99 pcms, if you can get your hands on one cheap.
somehow i seemed to have gotten it all wired up correctly now, trans stuff included. it looks like a big mess, but it works.
btw, it only takes 7 wires to the pcm to get it to work and the misc sensor power wires (pink coming off the sensor) and misc sensor grounds, pull vats off the pcm, and itll crank up and idle with correct fuel pressure. Once you get it running, you will see its as simple as they say.
Red connector
My harness.............my sheet.............what it’s for
1. black/white..........black.................PCM ground
4. blank................purple..........air solenoid driver
9. dark green/white.....dark green...fuel pump relay driver
11. dark blue............blank
13. blue/black...........white.............cruise control enable
signal
14. blank.................red/black........ac refrig press sig
15. brown.................red..............alternator term
16. white/black...........blank
18. blank.................dark green........ac status signal
19. black/white...........blank
21. purple/white..........blank
30. blank.................dark blue........vdt fuel enable sig
33. dark green............dark blue...eng cooling fan 2&3 driver
36. blank.................brown........air pump relay driver
40. black/white...........black............PCM ground
41. white.................gray.............EGR position sen gnd
44. blank.................light green.....rev inhibit sol driver
49. yellow/black..........blank
53. blank.................gray/black.........spark retard signal
55. dark green............blank
57. black.................purple.........intake air temp sen gnd
62. gray..................blank
Blue connector
1. black/white...........black................PCM ground
8. blank.................gray..........tps 5v. reference signal
12. dark blue..........dark blue/white.....crank pos sensor sig
23. purple..............gray.........fuel tank press sensor gnd
28. tan................tan/white......heated O2 signal low sen 2
bank 1
29. tan................tan/white......heated O2 signal low sen 2
bank 1
30. lt. green..........blank
32. black/white........gray...........clutch pedal position sig
34. white..............orange/black...........PNP switch signal
40. black/white........black.............PCM ground
41. gray...............black......EGR pintle position sensor gnd
42. blank..............dark green....eng cool fan relay 1 driver
54. black..............orange/black...........MAP sensor ground
59. yellow.............blank
60. orange/black.......black............TPS sensor ground
63. tan................blank
72. yellow.............blank
75. pink...............blank
80. orange.............black.........eng coolant temp sensor gnd
1 and 40 on each connector are the pcm grounds, obviously...so go ahead and get that wired up and out of the way. 2 and 20 on red are constant 12v and 19 on red is the ignition key on signal...those are the BIGGEST things you need to make sure of from the very beginning.
when i went in and did my harness, i pulled it ALL apart. got every sensor plug seperate...not a horrible idea, just REALLY time consuming. yes, i removed all the excess stuff "correctly" but i have 25 hrs into my harness and im far from happy with it. Don't really have a suggestion on what is best to thin out the harness short of spending the 300$ to get someone else to do it and make it look good if you dont feel like putting THAT much time into it. its not hard, just time consuming...
and it looks like most of the stuff in what you posted up was just where gm changed wire colors thoughout the years. I know all my PCM grounds were just straight black, but it was also an 02 harness to begin with.
check this link too
http://www.lt1swap.com/2001_ls1_schematic.htm
i used it some...along with everything else you have seen already. also, a CHILTONS manual is good to have. i bought one for that gen half ton and it has good diagrams in the back, but the pinout stuff isn't the best...but atleast you can find out what pigtail you have hanging around as a stray or what other wires need to be pulled when pulling egr, etc.
also, make sure your crank pos sensor is hooked up and wired in right...along with cam pos., sensor 1 bank 1 and 2 O2s (just to get it running a little better), IAC, and MAP. MAF is nice to have hooked up too. engine coolant temp isn't necessary, but nice to have also, since some spark tables are slightly affected by it. IMO remove all the egr, air, other emissions, etc crap you dont feel you need...because you dont. stupid crap like oil level and coolant level sensors aren't needed, and half of them dont even go to the PCM anyway. i didn't use any of the other body control modules...just removed that crap entirely and mine works fine.
The wiring on these motors is insanely simple...don't sweat it. there is really nothing to it. If i can get one running, anyone can...just make sure, like i said, the 7 important PCM wires are hooked up, grounds grounded GOOD (pcm prefers to be grounded to the head from what others have told me, and i have no issues with mine grounded to it...made my life better imo). The swap is honestly an easy one and id be more than willing to do one again. JUST DONT SWEAT IT!!! and ask tons of questions. i know i did...and mine runs like a raped ape!!
I'm building a moose buggy and I don't need any of the emissions stuff, so I had that all removed from the computer. I wanted to have all the information that I needed before I started into the harness but once I started getting into it a lot of the stuff was self explanatory (just following a wire from the PCM connector to the where ever it went).
I plan on using the 2 O2 sensors since I want it to run efficiently. All of the tranny stuff is history since I'm running a TH-400.
If I run into any problems I'll hit you up for info.
Thanks,
Gus
Thanks,
Gus
yeah, its pretty easy. only a few sensors NEED to be wired in for it to run, and you can always scan it to see what isn't working as it should if you run into issues.
Like i said, those 7 wires for the pcm, a few little sensors, 65+ psi fuel pressure, and remove vats, itll run...nothing to it.
