A couple of months ago while out wheeling i managed to bend the ubolts outward on my 1310 yoke allowing the ujoint caps to fly off. After that I limped her home and she sat all winter for a TBI swap. Post swap i took her out on a shakedown run and i managed to break off one side of the slip yoke on the driveshaft and at the axle. i purchased a 1350 yoke and driveshaft as a replacement but i know they have less of an operating range. Im running a Dana 60 with the pinion pointed up at 5* running a cv shaft ( measured with angle finder on the flat webbing that rides alongside the pinion). I’m a little confused with the caster and understand how important it is. l read I should have optimally 8* of caster so should I get a 3* shim and rotate my pinion up? This is an offroad rig that I very rarely run on the street. I have heard several times that my pinion angle is causing these problems. Thank you in advance
my 52's are completely flat and im in the market for replacements ( to level the truck and gain some uptravel so my pinion angle might get worse, so should i just get a 4-6* in preperation?
