OK, I left it out now.
But man was it a pita to set pinion preload
I'm on my third attempt now, but it's to loose this time (was too tight last time)
In the papers I got with the rebuild-kit it says 17-30 inlbs, isn't that really much?
For comparison, how much are wheel bearings supposed to be preloaded?
My info says that pinion bearing preload should be 20-40 in/lbs with new bearings or 10-20 in/lbs with used bearings.
Preload is the amount of resistance it takes to rotate the pinion gear, 40 in/lbs = 3.33 ft/lbs so no that isn't very much. Remember that it requires a DIAL type torque wrench to check pinion bearing preload.
and not just the break away tourqe also. and dont forget a seal adds around 2in lb i have been told.
also you should prob use a setup nut till exact. then use the new nut.
Yeah, its a lot more than wheel bearings. Pinion bearings are under a lot more stress.
BTW I believe the shim/baffle you pointed out goes between the upper pinion bearing and the pinion seal to keep oil off of the seal and make it less likely to leak.
I still think that is pretty tight for the rolling resistance of a bearing.
After all, 40in-lbs is 3.33 lbs at the end of a one foot long wrench...
I don't have a dial-type torque wrench,
instead I use a calibrated fishing scale on the end of a wrench and calculate the torque from that![]()
I know that it's supposed to go on the outside of the inner bearing, where the pinion depth shims are.
I just haven't figured out why...
But it makes sense that it's for oil control of some sorts.
There's another one outside of the outer bearing, and that one I already have.
Look at the diagram here about 1/3 of the way down, the washer/shim is number 8
I just put 5.38s in my front 2 weeks ago. Mine came out at .005 -.006 BL. Decent pattern and tight on the gear (new bearings as well).[FONT=Arial, Helvetica, sans-serif]Quick Ref Specs – Dana 60:[/FONT]
[FONT=Arial, Helvetica, sans-serif]Backlash
Set To: .004” - .009”
To decrease backlash – add shims to RGS
To increase backlash - add shims to non-RGS
Approx 0.007” change in backlash for every 0.010” carrier movement[/FONT]
That was my first thought as well.I think your pinion is too deep.
I've read up on the subject now, and it doesn't matter that the pattern is offset towards the center of the ring gear.
The thing that matters is that it's even from the "top" to the "bottom" on the cog.
And as you can see, my pattern was offset towards the top, which means the pinion is too far away.
