I have play in my pinion bearings in a 14bff. Enough to cause a lot of heat in short distances.... I'm buying a re-gear bearing kit but wasn't planning on doing carrier bearings just yet.
If I rebuild just the pinion, and use the same shims, do you think it'll change my gear mesh pattern much?
This will be the first time I've ever done anything but change the lube in a differential.
I HAVE been reading up on and watching videos of, changing and setting gears in this axle. So I'm not totally in the dark with it.
