Pinion seal
FL84K5
Sarasota, FL
Does anyone here have a problem with the rear pinion seal leaking whenever they go mudding? Every time I go my rear pinion starts leaking really bad. My front one never leaks though.
Could be getting water inside dff.This raises oil level and makes it leak.Change the seal put in new lube.If old gaer lube is grey colored flush bearings good before refilling. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
