brans87 1/2 ton status - In Memoriam - Joined Sep 16, 2013 Posts 3,018 Reaction score 838 Location North Carolina Mar 17, 2015 #1 Anyone know correct size for u-joint for 12 bolt truck pinion yoke? Jegs etc shows different ones and wanna make sure order right one time.
sweetk30 Back to play nice . Premium GMOTM Winner Joined Nov 1, 2004 Posts 43,011 Reaction score 25,461 Location in the back of your brain Mar 17, 2015 #2 fyi yokes swap from 10 bolt to 12 bolt with just a 10bolt FRONT pinion seal from a 80's 4x4 . I did this to keep the drive line all same . but I do know the 12 bolt is a little od size over the stuff we play with mostly .
brans87 1/2 ton status - In Memoriam - Joined Sep 16, 2013 Posts 3,018 Reaction score 838 Location North Carolina Mar 17, 2015 #3 http://www.jegs.com/i/Moser-Engineering/718/PY110/10002/-1 Pretty sure this is one I need as my ring is bent up and inside splines are little rough. Last edited: Mar 17, 2015
sweetk30 Back to play nice . Premium GMOTM Winner Joined Nov 1, 2004 Posts 43,011 Reaction score 25,461 Location in the back of your brain Mar 17, 2015 #4 link no worky
brans87 1/2 ton status - In Memoriam - Joined Sep 16, 2013 Posts 3,018 Reaction score 838 Location North Carolina Mar 17, 2015 #5 Fixed thanks for heads up.
