Found Pitman Arm for 4x4 Power Steering box
k10klub
Registered Member
New Orleans, LA
This is on a 1972 1/2 ton truck, I am converting from manual steering to power steering with a Redhead 2851 4T box https://redheadsteeringgears.com/product/28514t/
The shaft on non-power box is about 1.125" diameter & shaft on power box is about 1.25" diameter, so there is a difference. I am not doing crossover steering, so it needs to fit a 4x4 box with half splines and a notch. It's probably (?) the same for 1968-1976, Redhead lists those years for this box, not sure what changed in 1977, but I would be interested in anything that fits the description.
I have a 4" lift so I can use a drop arm if I put my stock steering arm back on, or I can use a stock pitman arm with my raised steering arm that is currently on the truck.
Ive got a handful. You looking for barret Jackson restoration quality or is a little rust pitting ok?
