Fred_M1010
I doubt ORD is getting their arm manufactured. It's probably stock for one of the vehicles already mentioned in this thread (actually 2, since they sell 2 different drops).
I think you are correct in assuming that.
My crossover pitman arm from WFO is based on one from a Jeep TJ/YJ,
but it is modified with a bigger hole for the DLE, and the keyways in the splines are grinded off.
But good reamers are really expensive, and it's hard to grind off the spline keyways in a hole.
So it isn't so expensive to buy one from a 4x4 shop after all...
I have about 4-5" of lift, and only have a slight rub against my stock crossmember with my bent draglink, when steering fully to the right.From pictures floating around, it looks like the high clearance crossmember is only needed for short lifts, straight drag link, etc. It seems like with 4"+ and the bent link it can be made to work.
It's better the closer to the steering box you can have the first bend in the drag link, so a shorter DLE is recommended,
like the ones that most 4x4 shop is selling that look like a TRE.
(but don't mistake them for a TRE, cause a TRE can't handle much angle at all)
I use stock DLE:s now and they are pretty long, but if I used a shorter one it wouldn't rub at all.
