Moody
This may sound dumb but.....I have been putting the front end of my 70 K5 together after swapping in 3/4 ton Dana and adding a 4 inch TC lift with zero rates. After adding the raised steering arm I am ready to install the dropped pitman arm but the splines don't match the arm ORD sent me. The stock arm had a split with a bolt to tighten it up but the TC one does not have this. I know the 4WD steering box has a notch in it and the 2WD box has splines...maybe I have a 2WD arm? I also noticed on some of pictures in other threads theres a nut that holds the arm on, but mine does not have threads for nut on the end. Do I have the wrong pitman arm or do I need to change the steering box?
