B
Bohemian
Guest
82 K5 Blazer Stock Axles & Suspension.
Does any body know if the threads on the pitnam arm tie rod end are left hand threads or right hand threads.
I figured they'd be right hand but I've been unable to bust that tie rod end nut loose yet with a 15/16" hand wrench, or a socket & a two foot breaker bar & I just tried my kick ass snap on 1/2" drive air impact that I've spun pinion yoke nuts off with which should be much harder to do than a tie rod nut.
It does not look rusted and it's a Nevada truck so even the body has 0 rust anywhere. Even so I've soaked the shit out of it with PB Blaster.
I also tried using the impact in both directions, but just a real quick blip back and forth to see if it makes any difference.
I'm reluctant to use the heat wrench or crank up the air pressure or impact anymore until I'm sure if it's RH or LH threads.
I'm trying to replace the leaking gear box and I can't even get started till I get pass this.
thanks in advance
thanks in advance
