ok so I searched and read through a ton of stuff but guess yall are way smarter than me as no one asked something so simple...
but I did get to reply to a topic!! hah
Steering problem
years ago I couldn't get my gearbox off so I swapped the 2wd shaft into my 4wd box.. but truck wasn't done so sat for a long time. I eventually drove it but was like the dukes of hazard steering.. back and forth to go straight...
Tried adjusting and adjusting and adjusting and could never get it to go so I removed the box, destroying the lines... put a reman box and new lines on and viola... waaaaay better, well sorta.. my
my issue is how to do an alignment...
now that my steering is tight, I drive down the road and the truck wants to go left and I apply pressure at the wheel to keep it going straight. if I let go of the steering wheel, she goes left...
when I put the gearbox on, I went left, right and counted the turns. went back to center, then spun steering wheel so it was straight.
well it is slightly off now but still...
can anyone list out the simple steps on doing this?
Steering problem
