Lawrence0485
Those are all interesting but other than the last 383, they are all mid to high range motors. I think I'm just going to copy the gm 330hp/380tq motor..it will be a huge upgrade as is but ill go ahead and pull the valves and clean the casting and do a port Match with the intake. I'm used to running premium anyways so do you guys think if my compression landed in the upper 9s to low 10s I'd be ok?
Here is the cam ill use unless one could specify a better one for this application.
http://www.crateenginedepot.com/Camshaft-Hydraulic-Flat-24502476-P9775.aspx
Haven't decided on the intake yet but I'm thinking either the performer or the performer eps..I'm leaning to the eps, it produces its max tq at 3500 which is close to the Dyno sheet I posted earlier
