This thread is a followup on my non-K5 problem, but I wanted to get a wider audience.
https://ck5.com/forums/threads/who-understands-obd2-evap-system.331347/
Jeep has a cracked nipple on top of the gas tank, causing a check engine light related to the evap system. I wouldn't care, but I need to pass emissions. I got under there, and luckily I can see the crack easily with the tank in place:
So I'm considering my options for some sort of plastic weld goop or something to fix it in place. I bought some JB weld plastic weld putty, which would be easy to push into the crack and wrap around the whole nipple, but is it as good as the two part? Anyone know if this particular type of plastic will bond with the JB weld? Any other options?
By the way, anyone know how to disconnect those kinds of connectors?
