play in the front driveshaft (at the flange)
SCOOBYDANNN
El Paso, TEXAS
how much should there be, and how can I fix it? i think i have too much om my 205 (ie. i can move the driveshaft like i forgot to tighten the bolts on to the flange) but the whole flange is moving. do I just tighten the flange bolt, or what?
I would think that either the bolt is loose or the output bearing is bad. Plus, that will probably make it leak.
