Please delete, new list posted
GonicGM
Seacoast New Hampshire
I just picked up a 1985 K30 SRW Standard Cab Pickup. Looking for the following.
350 Hydroboost hose from pump to hydroboost, must be 350, o-ring style.
Rear driveshaft TH400/NP205 to 14B FF, 131.5" WB, without yoke is fine, main shaft measures 57-7/8" outside-outside, joint to joint center 56-3/8", and weld to weld 52-7/8".
LF & RF Wheel wells, respectable or better
Positive Battery Cable 60"
Negative Battery Cable 25"
decent tan bench seat
LH AIR smog pipe for stainless header
good running 350 M code motor
LH muffler (round, H5D emissions)
LH tailpipe (stainless, H5D emissions)
Updated List
LH 350 stainless header with AIR smog pipe and good heat riser valve
Good heat riser valve (EFE Valve) for LH 350 stainless header
LF Door, LH front fender, tailgate in Code 72 Apple Red
Spare tire crossmember, just behind rear end, held in with two rivets.
LF rubber splash shield for wheel well, K-series truck.
Updated List
For 1985 fullsize K30 Chevy Pickup, Looking for the following:
Chassis brace for 85-87 K30,88-91 V30, mounts from RH end of rear cab mount crossmember to bottom of RH frame rail.
LH 350 stainless header, AIR smog pipe and good heat riser valve (EFE Valve) for 454 or 350 stainless header(85-88 4bbl 20 or 30 series)
LH manifold A.I.R. hose (from 85-88 dual A.I.R. pump system 20 or 30 series)
LF Door in Code 72 Apple Red(any 77-91 old style)
LH front fender in Code 72 Apple Red(any 81-91 old style)
Tailgate in Code 72 Apple Red(any 81-88 old style)
OEM fisher plow light plugs with pigtails, truck side, 4 pin square for Fisher Speedcast
85-91 Bellhousing with tin, clutch and brake pedal assembly, clutch reservoir, master, slave and line.(any 85-91 old style)
Camper Special stuff, Tie downs, dual battery harness & relay(73-91 old style)
Tan seat belts, clean, for bench seat std cab(any 81-91 old style)
Tan kick panels non-a/c(any 73-91 old style)
Spare tire crossmember, front(73-91 old style)
LF & RF Wheel wells, excellent cond.(any 81-91 old style)
Two bed floor carriage bolts (short ones)(73-91 old style)
OEM sliding rear window & gasket(85-91 old style)
Dual tank harnesses, RH lines, RH line clamp(any 81-91 old style)
Ebrake splitter/equalizer (any 84-91 old style)
Full length plastic tank shields for 20 gal tank, LH and RH
OEM working HI tone horns (any 81-91 old style)
Red glovebox(cover), mint, factory paint
OEM grey cardboard liner, behind seat.
Power lock harness.
Automatic steering column with delay and module
4WD indicator wire to transfer case, uncut
K30 SRW front hubcaps
Air cleaner/breather assembly from 85-88 4bbl, very clean.
Decent tan bench seat
Good heat riser valve (EFE Valve) for 350 or 454 stainless header
I have pretty much everything you need except the headers, but too far:dunno:
