1988 Chevy K5 Blazer
350 TBI, 700R4 transmission, NP208 transfer case and long tube headers with true dual exhaust.
GM Dana 44 front axle, GM 12 bolt rear axle 4.56 gears, Aussie locker up front, Auburn posi in the rear. Rockcrusher rear diff cover and heavy duty front diff guard.
4” lift, custom rear driveshaft with spare custom shaft and spare front and rear axle shafts and front drive shaft.
35” tires mounted on reinforced 15x10 steel wheels. It comes with 2 spares on 15x10 wheels.
Roll cage over rear seat, new sheet metal inside cab behind front seats and by tailgate. Both reinforce with heavier steel including rear body support made out of 2”x3” 3/16” steel tubing. Rear bed corners reinforced with 2x2 1/8” tubing. New body mount bushings front to back.
Comes with home made steel tube doors.
Homemade rear bumper with receiver hitch and 2 shackle mounts.
Homemade rockslider/step rails. Made from 1/8” 2”x2” square tubing and 3”x4” 5/16” tubing.
Customized Diy4X front bumper with 10k pound Smittybilt winch and 2 shackle mounts. Truck has dual battery setup with isolator. You can run the winch battery down and still start the truck with primary battery or jump primary off winch battery.
New gas tank with new fuel pump and sending unit.
I also have other springs and various other parts that will come with it.
Located in Knob Noster, MO. I will deliver or meet within 300 miles of my house for the right price.
$4000 obo
$4000 obo
