Please Help me UNdestroy my motor...
78Suburban
Georgia
read my other recent thread if this post doesn't make sense
Alright yall. a few quick questions...
1) when I turn the motor over by hand (with wrench on bottom pulley), do I need to take out the spark plugs, or can it be done with the plugs in?
2) what type of wrench or allen wrench does the plug above the filter take that I could put a sensor in??
3) once I get the timing close by finding TDC and aiming the rotor toward #1 piston, how do I precision tune the timing, and what should it be set at?
1 if you take out plugs it is easier(no compression) but you dont have to.
2 dont know
3 precision tune with timing light, i started at 10 and adjusted from there
I can't even find the mystery plug above the oil filter, does anyone have an engine on a stand that they could snap a photo of for me ? purty please... all I see are two holes that don't appear to have any kind of plug in them...
here you go, I just happened to have one on a stand
btw, if it is this type of plug, it is 9/16, if it is a square hole, it is 5/16 square drive, if allen, it is probably 5/16 allen
He topped it so I could find it and send him the picture because he's not a member. He said thank you very much by the way.
