Please take a look at my gear patterns
3MAX
North Alabama
I just installed new gears for the first time and would like input on how the patterns look.
Front Drive:
Front Coast:
Rear Drive:
Rear Coast:
Backlash on the front is 0.010, the rear is 0.008. Any thoughts are appreciated. Thanks guys.
what axles ?
and whats spec for b/s on the one in .010 bl . sounds little high.
and as the gears break in pattern will get longer. so the second one looks o.k. but i think should be doen just a hair to make room for breakin.
but what do i know i dont realy do gears.
The front is a 10 bolt and the rear is a 14 bsf. Both are 4.56 gears, and specs with the gears called for .008 - .012 backlash.
Everything I have seen says .007-.010 is where you want to be at on backlash.
The front looks a little low on the drive side but sometimes you cant get them perfect with every set of gears.
I just did mine also....back SF axle and front 10 bolt I went with 5.13s
Little bit bigger pic?
you can email them to me too. Pretty sure my e mail is in my contact info.
Those look fine from what I can see. But I like a little closer view
Backlash is fine, within specs is fine. And you are right on your specs ( going off memory here)
They both look good from your pic, the reason I would like to see a bit bigger pic is I think the front might be a touch deep. But very close. Can't tell from the angle and size of the pic.
When we installed gears at the shop we applied some pre-load to them by either lightly pressing on the brakes if the axle is together, or by pressing on the gear with a rag while it turns if the axle was apart. If your backlash is in spec, doing that gives a better pattern to read.
I thought that .008 - .012 seemed a little much according to what I had read elsewhere, but that's what the gear manufacturer (Motive Gear) called for.
Thanks - The pics are on my home computer. I'll send you some larger ones tonight.
i seen a set of richmond gears 1 time had .010 on the gear out of the box for bl spec and spec was .010-.012 range. :eek1:
