I'm planning on cleaning up the aftermarket wiring mess I made under my hood 10 years ago when I hastily installed my front and rear lights. I've been piecing together stuff of Amazon for parts, but wanted to get some input on the following from those of you who know:
Breaker:
https://www.amazon.com/gp/product/B..._title_dp_20?ie=UTF8&psc=1&smid=A6AY1HFZHO49U
Fuse block:
https://www.amazon.com/gp/product/B..._title_dp_21?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Relays:
https://www.amazon.com/gp/product/B...title_dp_18?ie=UTF8&psc=1&smid=A1L7F5DL4H71TK
Switches:
https://www.amazon.com/gp/product/B..._title_dp_17?ie=UTF8&psc=1&smid=ACKFGXOOEC78X
I haven't set my mind on those switches, but I like the fact that are all on one panel, and I have USB charging capability on it. I'd likely find a way to mount this on the front of my Tuff security console.
Thanks for any help you guys can give.
- On the attached diagram, do I need fuses between the switches and "hot" source? Since I want to be able to turn the lights on without the key on, I planned on just running straight from the battery to the switches (or the fuses if needed).
- I was planning on using 6AWG wire for the power to the 100A circuit breaker and then to the fuse block. Is that sufficient? Overkill?
- I was planning on using 12AWG wire for all of the other connections to/from the relays. Is that sufficient? Overkill?
- Are my fuse amp ratings sufficient for the lights I'm running? The 8" are 130w halogen, the 5" round are 55w halogen, and the back ups are 55w halogens.
Breaker:
Fuse block:
Relays:
Switches:
. Use a chart like the one below for appropriate wire size and max amp ratings for your situation. Remember to not exceed the wire's capacity with a fuse! Always go lower. It does no good if a wire can't handle what a fuse will let pass. When the wires split into smaller wires for different circuits, they should have individual fuses for those wires.
